Windows Users - Seeking Video Card Data
Which version of Windows are you using?
Windows 7 Enterprise 64-bit SP1
What is the make and model of your video card?
AMD Radeon HD 8750M 1GB
What is the current driver version installed on your system?
AMD video card driver 13.101.1.0
Does SketchUp crash or generate an error on launch?
Launches fine, without errors then freezes and does not respond on save every time. Fixed by disabling OpenGL Hardware Acceleration. Note: been using older sketchup version (v8) for 6 months without this problem before upgrading to 2015 where this issue appeared.
What version of SketchUp are you attempting to launch?
SketchUp Make 2015 15.3.331 64-bit
Windows 7 Pro x64-bit SP-1 Built 6.1.7601
ADM Radeon HD 7700 series
Launches fine, Bug Splat on occasion// user error though, I do submit.
Windows 8 64 bit
Intel HD graphics 5500 + AMD Radeon R7 M260
Intel 10.18.14.4038, AMD 14.301.1005.0
No, erratic crashes sometimes when idle.
SK Pro 15 64 bit
I moved 2 posts to a new topic: Sketchup keeps crashing when exporting a 2d graphic
Windows 7 Ultimate 6.1.7601 SP1 build 7601
AMD FirePro V4900
14.502.1019-150317a-183940C-Retail_End_User
2D: 8.01.01.1443
Direct3D: 9.14.10.01080
OpenGL: 6.14.10.13293
Launches fine, without errors or crashes.
SU Make 2015 15.3.331 64-bit
Does anyone know if it would run on a netbox? Considering setting up a chilblast microsystem for a friends workshop. He builds timber-frame buildings and designs using Sketchup but then prints out each section. Having it on a system in the workshop would be better but dosn’t want a full PC there. I think the processor would be ok (intel quad atom x5 z8350, quad core up to 1.9Ghz) but the graphics card is onboard, Intel HD graphics 400. Do you have any idea if it will run?
trying to run a 3D modeling aplication - which is demanding by design - on an ultra weak system (Atom is slooooow) is never a good idea… check the intel NUCs or build your own device based on a Shuttle barebone in connection with a core i3 … with an intel HD still being slow and with possible OpenGL issues depending on the driver version used.
Win 10 Pro Insider preview current version is 17123
Asus GEFORCE GTX 1050ti
391.01
No issues
SketchUp Pro 2018 64-bit
thanks for your response, very helpful and has probably saved me £100 :slight_smile: Maybe the Sketchup Viewer app would do what he wants… Anyone got any experience of it? can you open a plan from Sketchup and view all dimensions etc?
The viewer is basically SketchUp without any modelling or editing tools.
If you are following Norbert’s advice, use the £100 you saved to put in any Nvidia graphics card - even the cheapest you find will do better than an integrated Intel.
Which version of Windows are you using? Windows 10 Pro
What is the make and model of your video card? EVGA GeForce GTX 1080 Ti SC2 Hybrid Gaming - 11G-P4-6598-KR
What is the current driver version installed on your system? NVIDIA 23.21.13.9135
Does SketchUp crash or generate an error on launch? No. But crashes during VRay renders and will not allow different display scaling with multiple monitors.
What version of SketchUp are you attempting to launch? SU Pro 16975
Windows 10 Pro 10.0.17763 Build 17763
NVIDIA Quadro P400
26.21.14.3086
SketchUp Pro 2019 19.2.222 64-bit
Windows 10 Pro build 18363.476
NVIDIA GTX 1070
26.21.14.4128 (441.28)
SketchUp Pro 2020 20.0.363 64-bit
There might be some process still running.
Close all SketchUp related apps, then do a restart of the machine.
Then try to run the installer again.
10 ( :frowning:)
NVIDIA GeForce RTX 2060
26.20.100.6911
Negative
SketchUp Make 2017 (the last free version)
Everything is wokring fine for me, never had any problems (except the ones I create myself :grinning:)
**¿Qué versión de Windows estás usando?
windows 10 pro
**¿Cuál es la marca y modelo de su tarjeta de video?
KFA2 nvidia rtx 2060 6 Gg
**¿Cuál es la versión actual del controlador instalada en su sistema?
446.14
**¿SketchUp se bloquea o genera un error al iniciar?
All OK
**¿Qué versión de SketchUp estás intentando lanzar?
Sketchup pro 2020
