Sketchup on startup advised there was a new version, which I downloaded and ran the installer. Towards the end of the installation I got the following error message:
Cannot open Key
HKEY_Current_User32\software\microsoft\internet explorer\Main\FeatureControl_Feature_Browser_Emulation
When I clicked ok the installer promptly backed itself out and removed itself and the current version I was running.
On my PC there is no HKEY_Current_User32 folder in the root of the registry, and I cannot add a new Key.
Has anyone else experienced this issue ? or know how to solve it? I have tried Googling this but to no avail.
Is IE up-to-date, cache and temp files cleared? SU, like other programs that interact with the web, use the default OS browser even if you prefer to browse the internet with another browser.
Go to the MS update site and get latest system updates for IE. Some other IE maintenance to look into.
I have not seen this before but your research @catamountain makes sense. I’ll escalate to the QA team to see if they can test our installer. A couple of questions for you @mark_phillips1965:
What version of MS Windows do you have installed?
Are your System Updates current?
Have you done any updates recently or made other software changes?
What version of MSIE do you have installed?
I haven’t seen this from other users but if it’s a new update from Microsoft then it could start popping up all over the place.
Open up the command prompt as an administrator i.e. right click on the Windows 8.1 start icon, and select Command Prompt (Admin)
change folder to the location where psExec is located and use the following command:
psexec.exe -i -d -s c:\windows\regedit.exe
Regedit should now open
locate the offending key this may not be easy to find as Regedit is now running in Admin mode therefore the current user is now admin, which means Hkey_Current_User now refers to Admin. To find the key for the regular user look in Hkey_Users. On my machine the keys under here referring to the user are encrypted, however the content is not. I searched each one in turn until I located the one with the Key I was looking for:
HKEY_Current_User32\software\microsoft\internet explorer\Main\FeatureControl\Feature_Browser_Emulation which on my machine corresponded to only one entry.
Hi Mark,
I’ve the same problem in installing the sketchup in windows 8.1, the registration key authorization issue. I opened the regedit with your advice by executing psecexe.exe.it did work to get onto the main/ key but cannot show off the featurecontrol key. So can’t delete the key. When re-entry the regedit directly without executing psexec.exe , it shows the key feature control , but can’t remove, edit the key as i haven’t the right to do it.
