Why is there a selection tool delay in SketchUp (under Windows 10)?
Pity the Intel assistant did not work. I was able to download it and run it before posting the link. Try again later. A few days ago it wasn’t working for me either. There are some internal problems with Intel chips, making them susceptible to malware exploits. Intel is scrambling to ID problems and roll out fixes. Though if you are using a computer from a manufacturer, that company should be pushing out fixes for that problem. Keep trying.
That grayed out button means you didn’t have an older driver. Nice to know. The way Intel labels drivers is a bit confusing. That’s why the Intel assistant is useful. You many already have it installed. Check the installed tools in the lower right taskbar.
Also check your computer manufacturer for driver updates.
In SU17, go to Window > Preferences > OpenGL. Try 0x option for multisample anti-aliasing. Restart SU for good measure.
This is such a tuff bug. FWIW intel has created a number of problems for itself in several areas.
There seems to be a systemic development problem at intel right now. They may be paying more attention to fancy drone shows and friday happy hours than creating drivers that work well and other items. Or maybe things have just gotten too complex to manage in general. As I have followed this problem here and in other places, it a very complex set of multi-faceted circumstances that come together to create this problem, and it can be created from several different sets of factors, not just a single set of factors.
That didn’t work either.
Alternatively, I’ve started accustomising myslef with the ‘right-click and escape key’ as an alternative to the ‘left-click’. This is embarassing! :smiley:
I think I’m going to cough up the cash and get 2018 pro, but can you assure me that this issue isn’t happening in that version? Or that there’s a way to address it more effectively than roll back (supposedly necessary) Windows updates and hope to correct the issue?
I was finally able to use the intel assistant, and it turns out that I have the latest driver. So I have still not resolved the selection tool malfunction in Make 2017.
Thank you again for your patience and assistance.
I looked up your Intel graphics on the Intel site. I’m not seeing any mention of Win 10 driver support. @DanRathbun am I reading the Intel support right - is the intel HD graphics 520 discontinued? Or is that one driver download listed for Win 10 OK for SU indicating there is still some hope for this chipset?
I’m also having this problem with the trial of 2018 Pro that I downloaded.
Did you try the following fix for SU18 Pro trial?
That worked! Awesome. Thank you so much.
This graphics GPU is sixth generation and is still under active support.
NO, you’re not reading correctly, mainly because this individual GPU page is not the page to determine OS support. That page is …
https://www.intel.com/content/www/us/en/support/articles/000005526/graphics-drivers.html
The page that lists the graphics GPUs/Chipsets no longer supported is …
https://www.intel.com/content/www/us/en/support/articles/000005733/graphics-drivers.html
That driver set was just released last Christmas (2017.)
Thanks @DanRathbun, I get those links bookmarked now.
@jeffreywandersen, if performance changes again, next try lowering your anti-aliasing to 0x in SU > Preferences > OpenGL. And in the same menu, you also can disable Use fast feedback.
for SU 2017 (pro)
I’m also having this issue since 1709 (pro).
Since then, I worked on another pc with a lot of frustation.
Tonight, I’ve tried to update to 15.33.46.4885 without success.
I delete the graphic card with its driver.
After reboot, Windows 10 1709 installed 10.18.10.4358 (15.33.42.64.4358) for my i7 3770K (intel HD 4000).
SU 2017 is now functionnal. :alien:
until next reboot. :sweat:
Then, I install lastest, again : 15.33.46.4885
And now it work, after only 1 reboot. :upside_down_face:
See you next reboot.
edit / 2h later
I’ve tryed to determine which process could cause this lag. I use Autoruns from Sysinternals to desactivate everything from other softwares. After enabling MSASCuiL.exe, the next reboot was with the lag. Since then, the only choice I have was to try to delete again the driver, and hope.
After several others attempts, I manage to get back SU 2017 with lastest drivers witout lag.
For now I double crossed my fingers :smiley:
