Why can i not snap to anything when moving an object
Who at Apple hurt you?
Yeah. Well, completely ignorant, but you do you.
I’ll see myself out of this thread now. Good luck.
They are on. And i just remade the object and now it behaves and follows the axis.
It was not the updates because it still happened after updating, then worked after remaking it.
So annoying.
I would rather have a program that worked than one with overdesigned functions that require hacking.
That fact that the admins use Apple is a joke and is a direct insult to the thinking community that is not a slave to the fascists at Apple. I will always choose OpenSource and universal compatibility over proprietary software and hardware even if it means less performance, because universal compatibility is the most important thing to preserve. How do you justify the arrogance of kowtowing to Apple and expecting your users to make the same mistake?
Sorry about mentioning Apple. I didn’t mean this to become an OS war thread. I’m outta here too.
I can’t easily tell how Apple got into the discussion. The majority of developers are using PCs, and some features only work on Windows.
I am the culprit. Made a joke about Apple.
who pissed in your coffee ? take a deep breath, nobody is forcing you to buy a mac, in truth, most of the mac users don’t care about your opinion of their machines. We’re giving you advice based on your description of the issue.
could you give us a screen recording maybe ? because I’m not clear on what’s going on
I see you haven’t provided a file. could you? so we can see if it’s file related and probably rule it out ?
in some rare cases, people have their windows configured in a way that when they install stuff, they don’t have 100% of the admin rights enabled. because of that, some preferences can’t write themselves properly on disk. I’ll theorise it’s a vestige of the old free google era, but I can’t prove it.
well, that’s windows for you. windows updates don’t install ALL the drivers updates. you should install the Nvdia app for that, best way to be sure. and windows sometimes changes authorisations on stuff.
We’re not suggesting some haking. we’re suggesting proper IT techniques.
This thread is a waste of time. i am outa here, Mute.
Is the object you are trying to move in place by any chance “glued to” some face?
This sounds like an object being glued to some face. (or small chance: a DC).
I dislike Apple so much I’ve gone bananas!
In the 1980s there was a cartoon showing a computer exhibition, and in the background were a number of computer company booths, all with fruity names. Back then there was Pear, Tangerine, Apricot, Acorn, Blackberry, and of course Apple. In the foreground were two Apple staff, with one saying to the other: “We wouldn’t have had this problem if we had called it the Stewed Prune II!”
True but it also depend on the update too the more new update are available the old ones get less Prioritize but still work well for old users
I feel your pain… I have run into this problem on a number of occasions, and I can usually resolve it. It seems that inference does not work well across multiple levels of grouping. Make sure the objects you want to stick are at the same level or close to each other. Probably when it grabs crazy other objects, they are closer in the grouping hierarchy. I have also found that sometimes an object won’t stick, but if I duplicate (option+drag) the object, the new one behaves as it should. I then delete the old (non-sticky object). Give both a try and good luck…
You give unhelpful advice.
Length snapping should be set to off, it is a know issue that can cause errors when modeling.
There is no setting for ‘Inference Locking’
I feel strangely sentimental about the the OS wars.. :slight_smile: Sorry, this was not helpful.
