No snapping, rotating, scaling
Hi,
I recently updated to 2024 on Mac Pro 16 ( 2,3 GHz 8-Core Intel Core i9) running on Sonoma 14.4.1 it looks like after a short while I cannot snap to endpoints, no rotating tool, no scale. So far the only way to reset is to close the file and reopen. Quite frustrating. Has anyone else experienced this? Any possible solutions would be greatly appreciated. Thanks
Is this with the new graphics engine or with the classic graphics engine?
Please update your profile. It’s way out of date.
I havent used the graphics engine yet. will update the profile
You must be using one of the graphics engines in order to use SketchUp.
I meant, havent used the new one yet
So you selected the classic graphics engine in SketchUp Settings?
no idea, let me check …
oh, it is the new engine one selected
Are you still using an Intel Mac with AMD GPU? There is an issue we’re investigating, where on M3 Macs the model window can stop updating. You can do a save, close, open again, to get back into action, but it is likely to freeze up again a while later. Choosing the classic graphics engine is the only work around for now.
Thank you, I changed to classic graphics and so far no issues.
This sounds similar to an issue mentioned here:
Same issue here
Im on a Mac w/ Apple M3 running Sonoma and Sketchup Version 24.0.483.
any input?? It’s super annoying having to close the program and open again every few minutes.
Thanks
I see this regularly when models get larger, both in 2023 and now 2024. Try clicking on the desktop to activate the Finder then clicking back onto the SU window to activate SU again. This seems to clear it up for me when it happens. Clearly a bug in either SU or Apple’s window events.
Thanks. I’ll give it a go. Of course, when you want it to stop working, in order to test your suggestion, its working just fine :-/
that works But OMG, I have to do this like every 30 seconds to keep on snapping
I just upgraded from 2022 to 2024 and snap is not working well. I’m on a Windows computer and moving individual vertices. What happened?
Quick followup. I turned on Back Edges and I’m snapping much better.
It is getting close to 8 months since the last message on this thread. This is still very much a problem and a major inconvenience to have to continuously close and reopen Sketchup. Is there any resolution with this issue yet?
If you click on another app, then click back to sketchup, the snap tool activates again. Less time consuming than restarting sketchup, but it’s still MADDENING!
I have seen huge improvements on this with 25.0.659 for Mac, only losing inferences maybe once a day at most.
Using M2 Max Mac Studio on Sequoia - I CMD TAB to another app, give a click and then CMD TAB back to SKP and it works. No need to re-start.
