Where do I find Shadow Settings in SketchUp Pro 2021? The tutorial video says it is found in the Window menu, but that is 2018 version and I am training on the 2021 version. ANy suggestions?
Thanks DaveR. Got it!
I’ve another unrelated question about drawing circles (I am just coming back into SketchUp after a few years’ break) … I’m trying to draw a circle, and for some reason it’s come out as a hexagon. Did I accidentally indicate that I wanted my circles to have six sides?!
Call up the circle tool. Before clicking anywhere, type the number of sides you want, push enter.
Thanks, I typed 0 as circles have zero sides, right?! But error message popped up saying the number must be between 3 and 999
Not in SketchUp. Circles are represented by a number of connected edges. By default, 24 of them. If your circles are large enough you might want to increase that number but don’t do so unless it adds something to the model. Otherwise you create needless file bloat and potentially problems with tiny faces.
Thanks, it was not the polygon tool, I thought maybe I’d accidentally selected that, but no.
Also, the tutorial I am learning from will refer to both the PC and the Mac
You are so right, and so wrong. All geometry in SketchUp is represented by straight lines, all circles are faceted. The higher the number of sides the smoother the circle, but at a cost as Dave rightly points out.
Thanks, very helpful.
