I’m not sure where to ask for help with a Sketch Up drawing I’m working on.
If you can frame it as a question about using SketchUp or about a specific issue in a model, this is the place!
Cool. Thank you.
What I’m trying to do is draw the corner post from this Urn.
See my reply in your other thread.
Hello Try weakly,
you climb the foot of the urn.
you draw the curvature on one side with the arc tool by 2 points.
After you select with the black arrow tool the two upper edges on the side of your curvature.
you use the follow me tool and you select the place of the curvature and it’s finished.
if you can’t do it I’ll give you a little tutorial.
Good achievement.
Dominique
Bonjour Try weakly,
tu tu montes le pied de l’urne.
tu dessines la courbure sur une face avec l’outil arc par 2 points.
Après tu sélection avec l’outil flèche noire les deux arêtes supérieures du coté de ta courbure .
tu utilise l’outil suivez-moi et tu sélection l’endroit de la courbure et c’est fini.
si tu n’y arrive pas je te ferai un petit tuto.
Bonne réalisation.
Dominique
This topic was automatically closed after 186 days. New replies are no longer allowed.
