I just got a MacBook Air and have installed SketchUp on it and wanted to test my extensions on it using my developer licenses. But I can’t find the EW.lic file on my Mac. Where might it be? It isn’t where my extension developer page says, namely library/application support/SketchUp 2018 The SketchUp 2018 directory simply isn’t there and when I add it SketchUP doesn’t find it.
Any help appreciated.
Two possible causes:
Make sure you are looking at ~/LIbrary (your personal folder - ~ is standard shorthand for /Users/yourname) not /Library (the system-level folder). ~/Library is hidden by default in Finder.
Check your capitalization. macOS is case-insensitive but case-preserving, which means that the path you gave will not match the correct path
~/Library/Application Support/SketchUp 2018
Has the bug preventing extension developers from having extension licenses been fixed
Regarding the file I suspect it is generated when SketchUp first writes to it, rather than an empty file being generated on install.
I just can’t find it. I put SketchUp into the applications folder as suggested by my Mac at install, maybe that was a mistake.
I downloaded and installed a free extension just to see if that would help maybe create the ew.lic file but no luck.
I’m a a bit at sea with it.
yes, you can generate a license for your own extension. It works great on my pc but I just can’t find the ew.lic file on my new Mac
You get the license text from the extension warehouse edit page for your extension.
This is good news! Last thing I heard was that anyone signed up as a vendor was unable to use extension licenses because of some strange bug. When I last tried generating a license I still couldn’t use it.
I haven’t had a problem with it. Sorry for you.
that’s perfect. exactly what I was looking for. Thank you so much. The Mac is a bit different, I’m learning. I quite like it though.
