Where is the installed extensions folder on Mac
When an extension is installed via .rbz script, where do the files get placed on a Mac? I cannot for my life find them. Specifically I am wondering what the file path to said icons is once installed.
They are placed in a subfolder within your Library folder. Finder normally hides Library, and that is probably why you haven’t been able to find them. You can use Finder->Go->Go To Folder and copy-paste the following in the dialog prompt:
~/Library/Application Support/SketchUp 2022/SketchUp/Plugins
OMG Thank You! it’s the little things in life, like a file location after an hour of looking. :grin:
As an alternative, if you press and hold the Option key and then open the Go Menu, the Library item will be listed in the menu.
You can also type Shift Command L to open the Library folder.
