Where can I see the exact measurements of my objects?
Hello community,
I’m using SketchUp Make right now and I need to know the exact measurements of my objects. I made a breakfast scene with objects like a coffee cup, an apple, butter etc. and now I need to know the measurements like height and width of those objects (in cm). Is that possible? I tried to find it as good as I can, but wasn’t lucky so far.
Greetings
did you try to use the tape measure tool
You can measure them with the Tape Measure tool or add dimensions with the Dimension tool. Although not designed for dimensions of things like coffee cups,if you’ve made components or groups, you could get the dimensions of their bounding boxes with an extension like CutList which is available in the Extension Warehouse.
How will you be using these dimensions once you have them?
