Hi, i received a SketchUp File from a Client and have to measure the Objects inside.
If a choose an Object, where can i see the dimensions (W x L x H) ?
Thanks
Thanks
@mihai.s, these are probably “only” the sizes of the bounding box that happen to be the same sizes as those of the (grouped) model.
Yes. That plugin only reports the bounding box dimensions for the selected component or group. If the component or group was made with the axes oriented correctly, it’ll be fine for overall dimensions.
Another approach is to open the object (Group or Component) and then activate the Tape measure tool. This would let you see the distance between any two points, or the distance from an edge to some other point or feature, etc.
