Hi,
I was wondering if there is a way to get the dimensions on multiple objects at once? Instead of individually having to measure out the width and height of each object. I have 70 objects that I need measurements for, the depth and height, and it’s really tedious having to do it manually to all of them… Any insight as to how to make this easier would be appreciated!
It depends upon how you built/organized the model.
What kind of SketchUp Entity are the “objects”?
Example:
If the 70 “objects” are instances of one component definition and their individual sizes were established by scaling each instance while outside its editing context, then you can edit one component instance, apply dimensions and the correct dimensions are automatically applied to all instances of the component.
