When use Circle or polygon command does not appear number of segments. Bug
When I use SketchUp Pro 23.1.340 64 Bit, the commands circle or polygon does not show the number of segments whe I use Ctrl + -, it olny shows in the right bottom corner strange symbols.
Thanks for your help, I think it is a bug, because it was working well in other versions.
SKP.pdf (272.2 KB)
that’s the two symbols you can get by typing ctrl+ and ctrl- I’d say.
I wonder if it’s related to the similar problems such as typing a shortcut that sometimes type a letter in the measurement field and some ctrl/alt/shift shortcuts being broken.
similar to what’s @colin is mentioning here with ctrl + arrows
