Web: How do I make a pyramid?
Hello,
I’m using the Web (shop) version and trying to make a pyramid shape. The examples that I’ve found and followed do not appear to work on the Web version. The raise tool does not select a point but only the triangular polygons.
Is this user error, a bug, or a feature?
Thank you for your help.
Use Move tool
Are you referring to Push/Pull? It would be the wrong tool. For this you’d want the Move tool.
Push/Pull only works on faces.
Must be user error. I was going to show the same thing mihai did.
I have the same gif saved ready to post.
Hah! That worked! Thank you!
Someone should update the tutorial because it uses the push/pull tool.
What tutorial shows making a pyramid with Push/Pull? Can you provide a link?
You could push pull and follow me.
Pyra
None actually!
Put that in the user error column. I swore I saw the push/pull tool being used. Sorry to bug you all.
Thank you again.
