Washed out textures
Hello everyone !
lately I have a very frustrating issue with sketchup 2015 and I really need your feedback …
All the imported textures look washed out for some reason (gamma ??) … but when I export a jpeg
everything looks ok ! never happened to me before …! any ideas ??
(attachment : printscreen and 2d graphic export …)
thanks in advance
Lef
As a test, … do you still see differences when you switch OFF Shadows ?
Also I think Windows uses PNG for PrintScreen operations. If you go through SketchUp’s menu and export 2D to PNG file it it also washed out ?
If you go to the Shadows option and make sure Light and Dark sums up to 80 (or less) no color should ever be overexposed. If you set Light to 0 and Dark to 80, you should get the exact color defined in the material, with no shading.
thank you very much for the replies !
unfortunately , none of the tips worked … 000
I am attaching a side by side sketchup 2015 - 2017 comparison …
I am pretty sure that the real colors of the textures are the 2017 ones … :confused:
What happens if you toggle some settings in the [menu]Window->Preferences->OpenGL panel?
Pre 2017 versions had a different handling of OpenGL…
Yes! that’s it ! thank you Mike !
I switched to’’ true color’’ (openGL menu)
and everything turned to normal ! :slight_smile:
