Volume of a group?
Hi, I need volume of the group but the volume in entity info isnt showing up. Can someone help me?
Your component need to be solid. Can you share your model?
The component/group must be as clean as possible
As @rtches indicated the groups must be solids and they must have the faces correctly oriented.
Once fixed Entity Info will give you a volume.
There should be no exposed blue back faces in your 3D model.
@bmaxim is correct. Your groups need to be clean.
You should fix them yourself. You can get Solid Inspector 2 from the
Eextension Warehouse and run it on your groups.
Your profile says you are using SketchUp for Schools 2023. There is no such version. SketchUp for Schools is a web based version for young children which you are not using. Are you using a cr acked version of SketchUp 2023? Please correct your forum profile.
