Hi all!
Just wondering, is there a way or setting to choose so that one is able to view photos textures when editing inside a group?
For example, in the attached, I would love to be able to see the underlying plans when editing within the group I have created for my geometry?
Many thanks.
DaveR
November 5, 2023, 1:59pm
3
Instead of making the “underlying plans” a texture you should just import it as an image and leave it as an image. Then you will be able to see it when a group or component is being edited.
Ah thank you, so thats my problem! Cheers.
I made them a texture as split up the images and placed into different groups but guess I can do that in Photoshop and reimport.
Thanks again.
DaveR
November 5, 2023, 2:02pm
5
Even if you want to split the image into separate parts, you can still leave them as images.
I made this example showing an image as reference from a thing I’m working on at the moment.
Thanks Dave, gotcha.
I split the image up in SU so I could get the GF and 1F plans into seperate groups, as the below.
DaveR
November 5, 2023, 2:10pm
7
Do that in an image editor if you need to. Then import both as images.
FWIW, there is not a setting to make textures outside of a group/component context remain visible while editing the object.
Thanks Sir, perfectly understood. Much appreciated.
You can assign the image to specific tags and toggle these “image tags” on / off as desired.
