Vali Architects - Fence Plugin
Hello,
I used the vali architects plug in to make a railing virtually identical to what we use. I used it perfectly in one model, now when I try to use it in another, it is no where to be found.
Has anyone else had this issue?
Did you use this plugin in SketchUp 2024 both times?
If not, you will need to migrate the extension from the old SketchUp version.
If still on SU 24, you’ll either need to copy the extension manually or install it into SU 24 from the RBZ you got from Vali.
If you are running SU 25+, you can use the Extension Migrator.
I manually copied it, and now it’s working. must have been the old model. thanks dan!
