Hi everyone. I have a problem that’s been bothering me for years and I can’t find anything similar on the Internet. Basically, my V-Ray Lens Effects window is messed up and I can’t use any lens features because there’s no way to resize the window.
As you can see in the screenshot it goes all the way down through the Taskbar. Have any V-Ray users experienced this? I’ve tried everything I knew but was unable to resize this window. My display is 1366x768 if that can help somehow. Any suggestions would be much appreciated. Thanks in advance!
Is it a WebDialog ? Click in the body of the dialog window so it has focus. Hold the CTRL key and scroll the mouse window. Does the content change size ?
If it is native dialog, you could try to right-click the Desktop Taskbar, and choose “Properties”, then check the “Auto hide the Taskbar” option. Repeat and uncheck the box. Sometimes this causes the window will resize itself and position up above the Taskbar.
