When using flowify what does it mean when it says this, I have tried to google and cant find a solution! Thankyou
Go to the Flowify page at Sketchucation and look at the documentation. It’s explained there.
Can you share the file? It’s hard to know just by screenshots what is the problem. There may be a better solution though, you can use a texture instead of generating more geometry that will not be appreciated.
In your other post, I explained what the problems are with your model and what you could do.
Hiya, I am 3rd year uni student and being stuck on this is getting me behind. I do not have time to re-do the whole thing, you have told me their is problems with it but not what the problems actually are?
Bgarden mezzanine.skp (5.0 MB)
Just read… ‘tiny edges’ are a problem. Did you search and read about this problem?
I recreated the railing model, with appropriate dimensions for all edges, and Flowify applied it without any problems.
// edit
Besides having a lot of small edges, you didn’t create one of the groups correctly, leaving loose geometries and separate groups. Follow carefully the tutorials on how to use Flowify.
YouTube search ‘Flowify tutorial’
Hiya i redone my model to start fresh and resolve the mezzanine issues
but now I am facing this problem, im sorry I know this stuff seems easy to you
but I have tried to google what it means
Bgardenmezzanine.skp (5.4 MB)
I have now resolved previous issue, but still not working, you said that its because of the tiny edges is the problem but you managed to make it work? was that only when you scaled that larger? I can not change the design as its important part to my project
Read carefully what I wrote to you in previous posts and try to understand.
Watch Justin’s tutorial carefully at least once, he explains very clearly what you need to do, how and why.
what should groups look like for Flowify (in Justin’s video)
and how your groups look like
Again:
- tiny edges matter;
- loose geometry matters;
- correctly created groups matter.
