I am in urgent need of help. I have a large file which has never caused me a problem before and has not been resaved since it was finished.
Today, it appears that half of the model is missing. However, when looking at the components list in the model statistics, the items are still listed. How do i input this back into the model space?
That doesn’t help us help you figure out what happened to your original file but if you’re happy to just go about copying stuff to another file, go for it.
Drag the missing components (not yet in the model space) into your modeling space.
Do not use ‘Purge Unused’ yet until you actually used them again. Otherwise these components will be lost forever.
Standard cleanup process.Fixed incorrect tag usage.
Lots of components and materials to purge but still a ton of remaining components.
Purging unused components only removes the ones you are hoarding but not using in the model.If you had deleted them from the model space accidentally they will also get purgeed.
File size reduced by 65%.
Here’s the reduced file. There still appears to be a bunch of garbage and other unneeded stuff but I have no way of knowing what you thought had disappeared. Lookat it and see. Maybe you just need to unhide stuff. I’m positive you could clean this model up more than I did.
Whats strange is that it has never been resaved since it was finished and looked like this - have also opened it a ton of times since and never resaved - the date on the file is still the original that always worked - is there a known bug for this problem?
I didn’t go into the atrium. I turned on all the tags that were turned off and I turned on Hidden geometry and Hidden Objects in the View menu. That’s all I did beofre correcting your wrong tag usage and purging unused stuff from your model.
The only "bug"I’m aware of that would cause things to disappear from the model space is normally referred to as user error. Perhaps you selected those objects and then right clicked on them to hide them but hit Erase instead. They are next to each other in the Context menu and what they do looks the same if you don’t have hidden objects and geometry visible.
