I’m not real familiar with Trimble Connect. I’m trying to upload a file and it keeps failing to upload. I’ve tried it from the desktop SU Pro 2023 app (on Apple Silicon) and through both Apple Safari and Brave web browsers. Nothing works.
I’ve read through a thread from 2021 and it seemed that Trimble, at that time, was working to get 2021 to work with TC. The suggestion was to back save to v. 2020. I tried that to no avail either.
I don’t know if it has something to do with Apple or your computer. I just tested publishing a model to Trimble Connect and had no problems at all. That’s on my PC with Win 10, though.
Do you have Edge or Chrome to try, too?
Can you open SketchUp for Web?
( go to myaccount.trimble.com Products > View included apps > launch SketchUp for Web )
Hi, Mike, yes, I am able to open SU web. I use that a fair amount. Usually just for importing dwg files then downloading as SU files. For some reason, when I was using Pro 2020, trying to import dwg’s on the desktop always resulted in SU crashing. Probably an extension conflict.
No, I have not tried Edge or Chrome. I had thought, though, that Brave was based on the Chrome engine. I could be wrong. I’ll try downloading Chrome and see what happens.
I tested from SketchUp 2023 on my Intel and M1 Macs. File/Trimble Connect/Publish As… worked on both machines.
So, Trimble Connect seems ok with 2023 models, and publishing from either kind of Mac works. Could you try being on a different network, even your phone as a hotspot, see if that makes a difference?
I did this, Mike. I assume by “opening in 3D browser” you mean Sketchup Web. Yes, all of this resulted in a model created in Triple Connect that did show up in my Sketchup for Web app.
Interestingly, at one point in the process, not sure just where, a dialog box came up that seemed to allow for choosing my Trimble account. All that was available was Sketchup web free. My Pro subscription did not show up as an option. Yet, the cube created did show up in my paid account.
In the desktop app, can you start a new file (or have one open,already) then open the saved cube file from TC. ([menu] File > Trimble Connect > open model)
I was able to open the file of the cube via TC. Modified on desktop then it did publish back up via TC. I could open it in the Sketchup Web app and the changes were there. But, when I went to open it in TC, it took some time (for such a simple model) and then, while it shows as having been converted, in the TC 3D viewer pane, nothing is visible. I tried several “remedies” but the objects remain invisible in TC.
What is the best (quickest) resource to research the difference between SU Web and TC? And why one would want to use one over the other in any particular situation.
That’s odd. It shows two elements selected, though.
What happens if you click i (information)?
The main difference between the two is one being an editor and the other being just a viewer.
Can you share the cube?
