Update texture SKPpro 25 PS 26
Hello,
I’m having a problem with updating the texture in Photoshop26 and transferring the update to skp.
I usually open with “edit texture image…” but when I press Ctrl+S on the Photoshop26 file, it doesn’t update in the SketchUp file.
Some one does how to resolve this issue? Is it a problem of how photoshop handle file saving?
Thank you
I also tried to dowload an older version of Photoshop (v.21) to see if the issue was with Photoshop.
But still, the texture doesn’t update the right way. Nothing happens when I press Ctrl+S
When you press Ctrl+S you’re saving the psd file, you must export and use the same name when you save the exported image to replace the old image.
This works ok for me - if I save or ctrl+s after making a change it does what you describe
I would assume if it isn’t then your files are opening differently or are saving differently.
Here are my save settings in PS
Hi All,
Thanks for the help.
In the end, was the plugin I had installed causing the problem with Photoshop?
