Upcoming Change to Add Location
Looks like DG doesn’t have a global terrain solution either.
http://sketchucation.com/forums/viewtopic.php?f=15&t=67708
[EDIT] Turns out that our terrain coverage ends at 60 deg north latitude. That particular user was geolocating in Alaska is further north than 60 deg. I’m discussing options with our data team for sourcing terrain for the higher latitudes.
Wait, is there a difference between Make and Pro now? I have completely missed this but it would make sense.
Yes, 2017 make users only get 2D Map tiles for geo location. 2017 Pro users get imagery and 3D terrain in addition to the map tiles.
Bryce, I just sent you an e-mail with an example SKP.
Wow the new resolution is much lower than I used to, will this improve in the future?
Can you post an image and provide the location you are looking at?
The new imagery and terrain is now unusable for my professional work. I’m very annoyed.
I have the option of downloading detailed map and aerial data (including 0.5m 3d contours) direct from my Local Government Authority, but it’s in GIS & DXF format, so it’s difficult to bring into sketchup.
I also need Sketchup to recognize a local cadastral grid system, (not only WGS).
…And I need it to recognise and import GIS formats properly, including geo-referenced JPGs/PNGs, PDFs, SHP, MXD etc, preferably all through a live data link system.
It’s a shame that I have a number of Trimble SX10 scanners & other robotic total stations, some with amazing 360deg cameras, and professional aerial drones that can capture quality data - but there’s currently no useful way of getting that into SketchUp.
Did you try Trimble Scan Explorer extension? You can import real world projects into SketchUp. With all the resources you have acces to, sounds to me you’ll be less infactuated then most of others here.
I have Words, Pages and some pencils, too, but they did not get me the novel I intended to write…:smile:
So most of the Nordic countries are left out? The southernmost point of continental Finland is at about 59.8 deg north :frowning:
Unfortunately that is correct. I’m working with our data team to fill this gap.
It seems the northern limit might even be a bit further south.
I just tried the new Add Location mechanism at 45N 90W … aka Poniatowski, WI, United States
No Location Terrain layer or terrain geometry was created.
All that came into SU was the Location Snapshot assigned to its respective layer.
Add Location worked as expected when I tried it near Chicago 42N 88W
UPDATE:
Tried Add Location for Poniatowski this morning and it worked. Go figure…
Hello Cotty,
I’m confused as to how your Digital Globe Imagery screenshot above is so much clearer than any of my attempts at Geo location with SU 2017.
Mine is a meaningless, unusable, blurry mess?!?
They are screenshots from their web pages, not from within SketchUp.
The data is definitely there. I think you hit a spot that spans several seams in the data tiles. Basically a bug. The team is looking into it.
~B )
Are you zoomed in as far as possible before you ‘grab’ the location? The quality of the imagery depends on your zoom level since the imported image is essentially just a screen grab of the map viewer.
Not sure how to insert pictures, it’s also interesting to see that the latest imagery comes in offset from the original…
[/uploads/default/original/3X/6/3/634f0f6738c032dc77ceba99599e1dc9b0f001d7.jpg][/uploads/default/original/3X/5/8/582c2c6689b61e625fc2745beede09f917798979.jpg]
Martin Taylor
Sr. Engineering Specialist
Office Ph: 360.786.5970
Cell Ph: 360.701.8518
I wouldn’t mind paying for Pro if it had a geo location facility that worked. The new facility is useless. Surely SketchUp Pro users should have the option of paying a reasonable fee to Google Earth to allow access to usable images.
OK, I don’t come by here very often, so I just found this out a few days ago. My business relies heavily upon having good image resolution of homes. Digital Globe’s current data is subpar for my professional work. These are questions:
  1. I guess I could still take a screenshot, and then import it into Sketchup. However, I will lose the scale. How can I adjust for the scale when I don’t know the ratio?
  2. Is there a comparable software where I can trace over the outlines of houses (to scale?). Does AutoCAD do this?
  3. And just for my own curiosity… how much was Google charging for continuation of their map data?
Thanks!
Regards,
Andy
Looks like we are in the same biz. My (unacceptable) workaround is to save an image from Google Earth with a scale indicator, import it into Sketchup, draw a line the length of the scale indicator, use the tape measure tool to rescale the model, explode the image, create a component from it, lock the component, geolocate it, unlock the resulting geolocated image, delete it, and then proceed with my workflow.
Trimble, are you listening? Totally ridiculous compared to my prior workflow.
And, it’s far less accurate because the scaling is error prone.
The add location tool was what made me embrace Sketchup Pro over AutoCAD in the first place. Now I find it almost unbearable to use Sketchup for my purposes.
