I’ve been playing with lego units, and I wanted to compare the ones I made with someone else’s, so I downloaded Aaron’s little falcon from the warehouse.
Having exploded the main group, I cannot select several of the little groups at all. I can access them in outliner, and ‘’edit” their properties, but not select them in the field. Are they locked?
I tried that. I tried copying the file, I tried copy pasting out of the file… I tried taking the corresponding pieces out of the little millennium falcon…
I downloaded your modell, opened in my iPad and I don’t have any problems selecting any of components in any combination . Perhaps try to restart your iPad…
Looks like there are some strange things going on.
Double clicking in the outliner results in dataloss. @colin might have a clue?
When importing the original from the warehouse, it gets a temp name.
So, on my iPad, no problems. On my Mac, I could select with the Select tool, but not the Lasso tool. If I double-clicked into a component, the geometry disappeared, never to be seen again.
One funny thing, the components that show a problem were built in a way that presumably contributed to the issue we’re now seeing. Normally it would be difficult to ask someone to describe the steps they used to make something. It’s less of a problem when that happened on live YouTube.
That problem is not new for me, in the past somethimes i could select all component by ctrl+A, but couldn’t select by clicking on it… I thought it was the way the component created and forget about it… I can’t remember how i solved that, may be selecting with ctrl+A and explode i don’t know…
Aaron modeled the Lego pieces in meters instead of millimeters, to avoid too small geometry issues. This version of the model has gone through the 0.001 scale change to make it be life sized. If you now try to edit at that size you’re back to possible too small geometry problems.
A recent change has added a couple of new symptoms to those problems, we need to revert that change or do the change in a better way. At least we have an easy test case to show if things are good again.
Meanwhile, if you went back to the Aaron scale of working, the problems you’re seeing will go away.
