Cannot select item
I downloaded a model from the 3D warehouse and there is a bottle that I can not select. I just wondering how it’s possible…
I can not attach it as it’s too big, it’s called “Bathroom Accessories 03”…
I’m also seeing no issues with the model.
GIF 20-12-2023 12-47-01 AM
Interesting…I opened it in a new file and the problem still exists in my SketchUp.
I will restart the comuter and try again…
Thank you for looking into this.
At a quick look, I can reproduce the issue. Going to take a deeper dive in a few…
Edit: Quite odd. I can select them from the outliner, but not using the Selection Tool. Still trying to figure out why.
As an aside: The camera is set to parallel, a bad idea while modeling stuff like this in 3D. Also, this model has numerous heavily bloated groups in it. Using them for entourage is likely to make your model very hard to work with!
Thank you for looking into this. I never experienced this problem before.
Yes. I just tried and I can select them both - the small spray bottle and the big bottle from the outliner, but then I can no move, copy, or use any command on them…Originally I thought the layer might be locked, but that’s not the case…
I am working, so haven’t managed to restart the computer yet, but will try if that would make any difference.
That is usually the first on the list when software is not working properly.
OK. I restarted the computer and the issue seems to persist…
