Uninstall button greyed out in Extension manager
Does this tell you?
You were not able to disable it due to file permissions? (That doesn’t sound like expected behaviour.)
Yes. At the bottom there, the System have read/write, but Users only have read. And SketchUp is running with the current user’s permission. That explains why you cannot uninstall.
Presumably the extension is installed via a separate installer?
Affirmative.
I should clarify. The memory leak happens for me even if the navigator is not attached to my macBook. When traveling without the navigator, that was a real pain before I stumbled on the workaround of closing the default model window. Using the EM to turn it off and on was hit or miss because the leak would take off before I could even get the EM open. So I wrote a little script to toggle the extension between .rb and .rb! without running SketchUp, and that required write permission for the folder. Not knowing how the EM manages enable/disable, I thought it might be relevant, but from what you say I guess not.
As @simoncbevans noted, their installer runs outside SketchUp and the EM. macOS requests an admin password to allow the install, which is why they can write to that folder.
