Unexpected File Format - HELP
Hello all. Today I lost about 40 hours of work. When I attempt to open either the .skp or skb file I get the “Unexpected File Format” error. I am attaching the file. Any help would be greatly appreciated. My class assignment is due in just a few days. Desperate here!
https://tridentusahealth-my.sharepoint.com/personal/john_gresham_tridentusahealth_com/_layouts/15/guestaccess.aspx?guestaccesstoken=wfy1S88URDl7QMY4OF8DXCH9oZXuLeE16HJacsW7bYA%3D&docid=0f555a4b2c2f14c86977d994c70c666ec
Couldn’t upload the file so using a Onedrive link.
skp not attached, try again…
There you go. Thanks in advance for any help!
unfortunately it also fails on my mac…
john
I also can’t open it, Mac as well. Can you try sharing the .skb file? Also, I don’t know if versioning works for .skp, but if you had the file in your “OneDrive” maybe this tutorial could help?http://www.7tutorials.com/how-recover-previous-versions-your-documents-onedrive
I think google drive and dropbox have a similar feature if you’re using their native apps on your PC and have your SketchUp files in there. Also found this for windows:
Vista/Win7 also uses Shadow Copy Service to save previous versions of files. If you have a file you modified, but need a previous version of the file, right-click on it and select “Previous Versions”. A list will come up with all if the previous versions of the file that you can either open, copy to a new location, or simply restore to the original location.
Hope something there helps.
So far I haven’t been able to recover anything from the document on my mac. Please share the .skb.
Thanks,
Marc
Sadly, I was working from a flash drive going back and forth from school. So no shadow copies or backups.
Here is a link to the SKB file.
https://tridentusahealth-my.sharepoint.com/personal/john_gresham_tridentusahealth_com/_layouts/15/guestaccess.aspx?guestaccesstoken=haTTcRT74VLA4YYRKZgI27XRjJXkUbQCZQ17Bl77QOg%3D&docid=086fad018d1124abd8c53c9644c83ea3d
Aaah, a flash drive, you may be in luck. The memory controller on a flash drive intentionally rotates the blocks so as to evenly distribute the writes. There is a small chance you can get an older save by using a technique like this:
Howto Geek Link
Of course, don’t waste too much time on it, in case it doesn’t work. I did try the .skb, and it didn’t work. I’m sorry I wasn’t more of a help.
Thank you for trying.
I’ve already tried a few recovery programs, no good.
I guess I am out of luck unless there are any more ideas.
The .skb has the same problem as the .skp - both files are truncated. I’m sorry, but I haven’t been able to repair either file :frowning:
