Unexpected File Format - Help Please! recover please
Please correct your profile.
done. do u think it can be restore?
Thank you.
I wasn’t able to do anything with it but Colin might. Did you look at the .skb version of the file and try opening it?
I could only recover components, materials, and layers, the scene is empty. The file is nearly as big, so it may be that you have some components that include large parts of the scene. Look through the components to find the bigger ones, and rebuild the scene from those.
https://we.tl/t-sb3JJ40eiD
I do not understand, I do not see anything in the file
Look in the In Model Components. You’ll the components Colin referred to. You’ll still need to reassemble the model by bringing the components out into the model space.
Did you look at the .skb file as I asked?
Yes, the SKB did not open either
What is meant by “Model Components”?
[image]
[image]
“In Model Components” in the Components panel. Click on the little house icon.
Yes I understood … Thank you … Unfortunately the rabbi has almost nothing there. The model was very complex and I worked on it for two days … It is not clear to me why this happened. this is very frustrating. Anyway, there is a link here to some files I saved of this model and they are not all opened. Is there any hope of saving him?
[image]https://wetransfer.com/downloads/475e06de22a16ce5fb99a15848e053af20220629205043/1d90eb74155b2343987b62cd1aa2bdc520220629205120/d143e2
It seems that most of the time when files become corrupted as yours is, the best you can hope for is components, materials, and tags which is what Colin recovered. The most common cause for this seems to be a Save routine that fails due to a connection problem when the file is saved to a network or cloud location. Have you been working on files saved directly to the cloud?
I saved it to local…
Are you using a lot of entourage from the warehouse?
not alot… Do you suggest that I start rebuilding the model?
At this point that makes sense. You should at least be able to pull the components out of the Components window so at least you won’t have to make or download them again.
thx alot
Good luck. Save early and save often. Might not hurt to use Save as… once in awhile and give the file a new name to make incremental versions.
Hello, I have da same problem with my file "
Unexpected File Format". Can you help me, please?
Thanks so much!
Link to download file (has 41MB):
[A073_AJM_MODELO_R04.skp - Google Drive]
help me please WeTransfer - Send Large Files & Share Photos Online - Up to 2GB Free unexpected file format ( gmail : elsent907@gmail.com )
I wasn’t able to recover anything from those files.
Hello,
I have the same “Unexpected file format” crash. It is only file I had. I couldn’t find any autosave files, then main one (.skb), and it acts the same. So both files .skp and .skb are crashed.
Please, can You check if it is possible to get anything from this file, because there is two weeks of work behind it.
trkolica_02.skp (9.6 MB)
Thank You in advance
Braca
