You will need to post your corrupted file to the forum so others can download it if you want someone help.
hi how to upload my file to forum?
First off, are you really using SketchUp free on the web as your profile says? And what exactly is the problem with your file?
To upload a file you drag it from your desktop and drop it into a response window. Unless the file is too large then you would use a transfer service and post a link.
Uploading: Screenshot 2022-05-19 153633.jpg…
this pop out when i try to open my file after a save this afternoon.
endlessfix was suggesting that if you post your SKP online somewhere, and give us the link, we can try to look at the file.
Drag the .skp file in question from your computer and drop it into an open response window. If the file is too large the you will need to use a transfer service like Dropbox and post the link here.
If you are really using SketchUp free like you profile says then there are more steps, you will need to download the file first, but your screenshot implies otherwise, a good reason to keep your profile up to date.
Hi, I having the same issue. Can help to recover? This is the link:
https://we.tl/t-A1eXZRXZit
Thank you.
We have been looking at your file, trying to recover anything. So far it’s not looking hopeful.
This file was 260 MB, do you remember if the size of the file was bigger earlier on? Do you have any copies of the file from a while ago?
One thought, if you look at Properties for that file, does the History tab show any older versions?
What kind of SketchUp license do you have? You appear to be using 2021.0, and there have been six updates since then. Is there a reason to be using that version?
Yes it’s 260mb only. Just remember after add in model downloaded from 3D warehouse then after Normal save.
Do you remember what model you downloaded?
Drum set from 3D warehouse.
In the data I can see that at some point you downloaded a file that is named:
“dw+drums+perche+cymbals.skp”
Does the name help you to remember what text you searched for? The temp file when it was downloaded was stored in this folder:
%LocalAppData%/Temp/
You can copy that path and paste it into the path field in a File Explorer window. When you get there, is dw+drums+perche+cymbals.skp still there? If it is, upload it to wetransfer.com and reply with the link.
This is the link where I downloaded.
Thanks, though that link downloads a file with a different name. I’m trying to find out if I can get the same named file from 3DW, to see if it gives me any trouble. I will test with the Roland kit in the meantime.
What is the reason you are using SketchUp 2021.0?
please help me too. I got this problem
i already try skb file but it’s not working.
when trying to open the file unexpectedly, this error occurred.
I tried renaming the skb to access the backup copy as it would be little lost work, but the same error occurs
Please recover this file mentioned above we transfer link
I’m having the same issue.
Please help.
Hello I am facing the same issue on a very vital file. Please can anyone help me recover it, I would really appreciate it.
