Hey everyone! I am trying to solve a workflow challenge. All of our parking lines are drawn as single lines inside Autocad. Is there a plugin or process that has the ability to take all of those single lines in sketchup and turn them into a plane that can be draped onto my road geometry?
With adebeo pushline extension
or you can make all those lines as components (s4u to components) and then replace that with another component.
Oh wow thank you! Does the Adebeo plugin work if some lines are along a straight line as well as curved? Or will it only work with perfectly aligned lines?
Here is the result I get with the plugin currently.
For that particular distribution, you can use the 2nd method, with s4u to components extension
Oh wow thanks so much! This certainly is the solution. I very much appreciate the help!
