In another thread - I was helped out to add some through holes in my object imported from a .dxf file.
I used the line tool on the outside of the object to see if I had a Face. In that .dxf file the object turned white (face) and I was able to select all the holes and delete them easily by
using the select tool, draw an box around a group of holes.
right click/intersect faces/ with model
In this new file, I’m not getting the “face”. the line took on the outter edge of the object does not turn the object white. And using the selection tool to select a group of holes, then intersect faces/with model I get the following error:
no intersection found between selection set and rest of the model
what’s going on here/or what is the issue? How to create the “face”?
