Apple MacBook Pro getting error messages within Sketchup program when trying to use extn tions and 3D Wharehouse. 502 ERROR BAD GATEWAY and 504 ERROR The request could not be satisfied.
Open a browser and go to extension.sketchup.com, log in and download the extension.
Then, in SketchUp, go to [menu]Window->Extension Manager and install the downloaded extension manually (red button on bottom left ‘Install Extension’
If you don’t succeed directly, you might want to close SketchUp and clear the webcache in ~/library/Application Support/SketchUp 20XX/SketchUp
and try again
I have seen some reports about 5xx errors in some SketchUp systems. I’m checking to see if those would affect the warehouse sites.
I heard back already, those other systems that had 5xx errors shouldn’t be affecting 3D Warehouse or Extension Warehouse.
Are the problems still happening?
Yes 504
More info CloudFront attempted to establish a connection with the origin, but either the attempt failed or the origin closed the connection. We can’t connect to the server for this app or website at this time. There might be too much traffic or a configuration error. Try again later, or contact the app or website owner.
If you provide content to customers through CloudFront, you can find steps to troubleshoot and help prevent this error by reviewing the CloudFront documentation.
Thanks Mike but I have owned Sketchup since inception,@Last, think I got that part about 4 years ago. Appreciate the thought. When I started on with Macs in 86 the big thing techs would ask is it plugged in! Many times that was the problem. Extensions are loaded fine no problem but some of my plugins extensions rely on the internet for activation and function. That is not happening.
