You can cheat and draw lines From inside edge to the outside edge of the Nut . . Looks like you did not get the Hole on center of the Nut for the Threads to be installed in it . . Or you did not get the distance right like told it to make threads longer then the part was . . Like making a hole and using Push Pull to go through and you get a bit on the bottom side of the part as it went past the bottom edge . .
