I’m having trouble creating a fluted column, where the base diameter is larger than the capital diameter. I’m sure I must be missing something.
I tried to start at top and create the flutes and push/pull the whole plane down the the base, but I cannot figure out how to stretch it to fit the bottom diameter
It should be easy enough. Note I only selected the bottom of the column. I scaled about the center of the selection and used a corner handle. Then I typed the desired dimension including the units.
