Trimble Connect share before assimilate
H All,
Just a quick question. Do you have to wait for the model to assimilate before you can share it?
I have never managed to get this to work on anything but tiny tiny files so I must be doing something wrong.
I update the file to Connect and then share. Is there anything else that I should be doing???
Thank people.
upload that is
This is all I ever get in the viewer when it opens
@Grey,
It would be good if you could share the model with us to see. Sometimes TC for Windows works best with large models. If you want to give that a go >> and if it loads properly >> then you can create a TrimBIM file out of it >> to view and interact with on the web version of TC as well.
Thanks for responding. I must be doing something wrong as no big file - and most of my files are big - has ever opened. This one is 234MB. I get the message above every time. I can’t share the file as it is confidential sadly.
What browser do you use?
Sometimes, it helps to clear the cache.
If a model has problems loading or taking to long, you can click on the loading icon again to trigger it.
Hi Mike, I use Edge but I will try it on Chrome to see if I have the same issue. I will try clearing the cache to see if that helps.
Hi @Grey,
I totally understand about the confidentiality of the file. Can I ask you to try downloading Trimble Connect for Windows here (assuming you are on a windows machine) and see if you can get the model to load.
If you are able to get it to load on there then we can create a TrimBIM file that should easily load on the web version as well.
