Trackpad two-finger swipe to orbit is broken
Hello, everyone. All of a sudden using two-finger swiping to orbit the model is inverted. I tried toggling the trackpad setting for inversion, and it has no effect; the behavior stays the same.
If I use the actual orbit tool things move the way they are supposed to.
Any help is appreciated.
I see the same problem. I will check an older version…
Older versions seem to invert ok. I will leave a note for the web team to look into this on Monday.
Same here, using Sketchup Go on a Macbook Pro. Nothing changed. Yesterday it worked fine, today Pan and Orbit are reversed and flipping the toggle in the options does nothing.
The team did look at the problem this morning, and were able to fix the issue and update the website. Things should look good again.
I’m confirming it’s fixed on my end.
Thanks Colin!
I’m so sorry for my lack of replies in this thread, things came up during the week and I only just discovered there were responses.
I just looked into it and the problem is now fixed! Thank you so much!
