Hi There,
Trying to create terrain out of a 2D site plan and looking for the easiest way to do it?
Here Im using Toposhaper and have removed the height point numbers to create the terrain but then after cleaning up contours and click on generate terrain it remains FLAT?
Thank you, That’s kind of what I thought it was but wasn’t able to get through the cleaning process.
so I first removed the numbers and reconnected the lines before cleaning up.
Ran and then clicked to remove junctions, then an error occurred then clicked done but didn’t appear to complete the cleanup process.
After the cleaning process, if I can get through that, - when setting the altitude, should I go by the numbers on the site plan or should I set the height starting with 1 and increase by the numbers as indicated on the site plan?
If those are just showing up as short line segments then yes, that would be the reason. There are extensions that will close open gaps but I don’t know how well they’ll work on those.
Thanks Dave,
haven’t yet found an extension to connect the dots did try weld. guess I can always do it by hand but hoping to avoid and learn something new.
