Hi all and thanks for your time : )
I’m working on a component for prototyping and ultimately CNC machining. I have a number of complex/variable curved faces and edges which require 0.75mm (0.75m in model) chamfers that terminate to a point. How do I model this tool path accurately?
I have found some success with solid subtractions. Using the follow-me tool to match the edge contour then bending to mimic the chamfer tool gradually pulling off. However, this is a sort of freestyle method with the bending and although it does the job visually it isn’t passable for a finished product.
Here is the model if anyone would be so kind as to give it a go.
https://www.dropbox.com/scl/fi/d868sp7y … 5u9hl&dl=0
Any thoughts, feedback, and recommendations are greatly appreciated.
Thnx again
