Can you share the LAyOut file so we can see exactly what you have set up?
Greetings,
I have shared the file in question. Note that page 4 is the only page which is at full scale, and it comes from a different model than the other pages. I also separated it out into a layout file of its own, but the results do not change.
Chris
Does this one print OK for you?
Jack and Jill Bath eastlake cornice.pdf (15.4 KB)
I will try it tomorrow when I am back in the office. I do not have the larger printer at home. I will be curious if it does, since it has not worked out in pdf for me so far. Thanks. Will let you know.
Digging a little more. Is there a reason you are using three different SketchUp models for what seems to represent the same assembly?
I notice some problems with your LO file setup. You need to create scenes in SketchUp for the views in LayOut. It’s really not a good idea to use the Last saved SketchUp view for the viewports.
I took the liberty of revising your document. I added scenes for the various views of the model. I put the side and front views on the same sheet. You can right click on one of the viewports and choose Open with SketchUp to inspect the model. I’ve reduced the references down to a single .skp file instead of the three you used. I also redid some of the dimensions.
Jack and Jill Bath eastlake cornice revised.layout (1.9 MB)
