I’m refining my construction documentation pipeline between SketchUp Pro and LayOut. While the basic link works fine, updating complex drawings across dozens of pages often leads to viewport rendering delays and tag visibility issues when new geometry is added.
How do you set up your base template scenes in SketchUp Pro to prevent accidental overrides in LayOut?
Do you prefer Raster, Vector, or Hybrid rendering for construction sets, and at what stage do you make that switch?
Are there specific naming conventions or tag structures that save you time when managing revisions?
Any advice, templates, or setup tips would be greatly appreciated!
Your forum profile says you have a SketchUp Go license. It also says you are using SketchUp 2019 and 2022. This is contradictory. You wouldn’t have access to those versions with a SketchUp Go license and you wouldn’t have access to LayOut. It would help if you straighten out your forum profile so we can give you appropriate advice.
As far as the time to render in LayOut goes, you should update to SketchUp/LayOut 2027. It is by far the fastest rendering of any version. Leaving viewports rendered as Raster will further help to speed things up.
Your “base template” in SketchUp should have no bearing on preventing accidental overrides in LayOut. Disable SketchUp model editing in Preferences in LayOut to avoid accidentally overriding Camera properties for viewports in LO.
Set up scenes for the views you need in SketchUp and use those for viewports in LayOut.
If needed, turn off Auto Render for viewports in LayOut so you can render only the ones that need to be rerendered after changes in the model. Turn on Auto Render at the end before exporting to PDF to ensure all viewports are updated.
With the current version of LayOut you don’t have to make a switch from Raster to Vector or Hybrid. You can use the Output Override to do that during export.
