Tips about procedural substract
Hello, I tried the new procedural tools thinking it might come in handy. But faced some problems I managed to resolve, so I thought It might be nice for others to know, so that they work around them
I thought I could create openings that I could then adjust, using components as cutter solids like this :
first problem, i can’t select them all at once to cut the cylinder as tools says it requires exactly 2 solids. alright then, let’s make it one by one. But once I create one opening, it keeps the second one selected and use it as a cutter for the 3rd. What’s the point ?
cutter
alright then, let’s pick the tool again or again or assign a shortcut to it !
It becomes very unintuitive, only the last operation is shown but we have a procedural group inside a procedural group inside a procedural group, for each of them…
proc groups
So I tried to make a procedural copy along path of the cutter component, and it seems it is the correct way to do it. But ! there is a strange behaviour, if we cut the procedural copy along that we used for the procedural substract operation, the solid that had been cut out is plain again (as expected) but still considered as a procedural group
gr
in the end, nice new tool, but very unintuitive and improvable, to my mind.
cheers
One of my pet peeves about SketchUp is the dumbness of the definition of “solid” objects. A group or component that consists of solid subcomponents is not considered a solid. In this case, if you put your cutting volumes all in a group and explode them there, the group is a solid and the subtract operation can then be done in one go.
the procedures need only 2 elements interacting, but then they can be made more complex later.
follow-me need one face and one path. but once it’s made, you can modify the face and make it two face. or three. they don’t even have to touch. and it’ll work of with the result.
same with subtract. you can subtract a single block. then, edit the block’s group, and add more geometry in it, it’ll also cut (just don’t nest them, have a single group containing all the blocks as raw)
I’ve had a couple of occasions where it was simpler to make a simple operation then edit it and complexify it. even during the live demo, Aaron made a simple wall, then added cladding on the face and it made a cladded wall. then he made a single window, and so on.
Plan B, in your case, is to make nested operations, first a path copy then use that as a cutting volume. it tends to bypass the initial limitations.
this new tech is exciting, but as Anssi says, it rests on legacy logic, still a good margin of progression.
thanks for your answers. good to know I then have the possibility to add any geometry afterwards ! I faced a few true bugs going further on that I’m afraid I won’t have time to expose today, but at least they did not produce bug splash. I guess I have to get used to its own logic. have a good day
Therefore, this implementation remains partial and does not yet allow the full potential of procedural modeling to be realized.
