I’m a web only free version.
why the selector doesn’t show the encircling dotted square to indicate the selection of various objects?
I couldn’t find anything anywhere in the app to help. I’d appreciate any help, thanx…
Generally that’s a graphics issue. Which browser are you using?
Your profile indicates you are using a rather old Mac. Apple hasn’t supplied updates for the Nvidia graphics cards for some years. That may be the problem, too.
Which browser are you using? Check if there exists a newish version of Chrome that you could install. I understand that old versions of Safari tend to have problems with WebGl.
I was using the 2017 version previously and never have had that problem. It does select many objects when I encircle them, but it is really uncomfortable not being able to see what I’m doing.
Is there anything I can do?
The desktop version uses OpenGL while the web version uses WebGL. Different critters.
Please answer the question about which browser you are using.
Safari
So as @Anssi suggested, use Chrome. Safari is not a recommended browser for use with SketchUp for Web due to inadequate WebGL support.
Safari Versión 13.1.2 (13609.3.5.1.5)
Ok, I’ll do that and report back. Thank to you all.
See: Getting Started with SketchUp for Web | SketchUp Help
Especially the part about using a recommended web browser.
Following your advise I wen to help and installed the Firefox browser then in SketchUp I opened Preferences, once there opened the Open Gl option and choosed: 0x. That solved the problem. Thnks again.
Well, that wasn’t my advise but since it worked, that’s good.
