Hey guys, you may like to see some detailed Sketchup models and how they are being used to push through the material shortages in Australia and, from all accounts, the rest of the world?
Carpenters are scrambling to relearn old school methods of pitching rooves and cutting frames onsite, so I made a video on why and when to chose trusses over hand-cut pitched rooves. I hope it helps you guys:
I am not aware of the situation in your parts, shortage is here, too. I am not that present in the construction area as I used to be.
We might take it back even longer, not 30 or 300, but way back in the early middle ages.
There was no shortage of timber at that time, but space was. The lots in the early cities were about 30 feet max and the the typical set up was inherited from farmer houses, a bunch of poles dug in the ground in four or five rows.
Having only reed as roofing material (lots of it) the pitch of the roofes needed to be a minimum of 45 degrees and usually 4:3, which was easier for the carpenter (3-4-5)
These houses were all heated by a fire in the middle. The smoke took care of preserving the construction and was let out by some holes in the roof. It was also used to preserve meat and fish.
But space even got more sparse in the cities and they skipped the two lower rows, moved the fireplace to the side and built channels for it.
Now, the attics could be used for storage and sleeping.
As I see it, the roofs in your parts are there for the trusses onlyâŚ
I am not advocating to introduce the traditional timberframe back, but we have have built some with laminated wood (bigger dimensioned wood is also sparse) and prefabricated sandwich roofs (ply, sls and isolation)
Very simple to make/adjust at site or in the shop and only raw materials needed.
Trusses serve several purposes here Mike (store junk):
- Speed of installation being the main reason as labour cost is super high, (more so with a skilled trade shortage)
- A lot of designs are open plan here, and a truss will span unsupported
- Most carpenters these days do not know how to cut a roof onsite
4We rarely have vaulted ceilings or raked ceilings here, I think itâs mainly due to the cost associated with heating and cooling unused space. It gets bloody hot in most of Australia and in many parts it gets below freezing for 3 months of the year.
Trusses are good for running service: EG Airconditioning, special lighting, ducted vac water pipes etc ( not that you canât do that with a pitched roof I suppose)
My personal choice is a pitched roof, but I am getting old.
A pitched roof is usually the premium option, and most do not care about things they canât see⌠.except when the cornices (crown molding) start cracking.
Well, the average footprint of Australia (and America) exceeds most of us regarding energy, I suppose. We builders tend to âgive what the client wantsâ. There is a role for the designer, I believe to move towards a more sustainable approach.
(I live in an old house single glazed windows, with energy label H, one of the lowest. I tend to joke that I actually do have double glazing, but live in the middle of it ![]()
Yes, there is the advantage of the open plan, but taking in to account the human aspect, how large can a room get before it starts to feel uncomfortable? Maybe itâs just a luxery problem. When the time comes to get rid of supporting internal walls, there is usually a way to divert the loads by placing a steel beam or something. Anyway, donât underestimate the power of laminated sandwich panels:
With less supporting girders needed.
Great video Andrew⌠very well described and easy to follow ![]()
I can imagine the chippyâs face when I tell himâŚyour job this week is to cut 450 birdsmouths in the rafters ![]()
Iâm in favour of pitched roofsâŚvalted/skillion ceiilings are pretty hard to beat. But how about making the whole roof offsite then heli-lifting it into place? ![]()
Not too familiar with Aussie but here in NZ the only thing that saved a lot of those old houses from falling down was the quality of that original timberâŚit didnt rot, was stable and very tough. We also kept to single-storey, pitched roofs and the building sites were basically flat. I just donât think Iâd put too much faith in Pinus Radiata for main bearers.
Andrew for pitched roofs is it typical to add steel straps or ply roof underlay for additional bracing? Or do purlins take care of that?
Cheers!
do have double glazing, but live in the middle of it.
Funny Iâve not heard that before. ![]()
Yes I agree we do build homes bigger than what we need, I guess it is because we have so much land vs population, and our kids never move out.
Yep, the client has the final say or the builder finds another job in most places around the world.
I design and build and rarely build anyone elseâs plans so for me it is about doing my best to educate the client but as you say clients always have the final say and rightly so as they pay.
how large can a room get before it starts to feel uncomfortable.
My answer is when it Ecos, as then it becomes unbearable. I made this mistake in my combined kitchen lounge living space, ill never do it again, too many hard surfaces & not enough soft furnishings. I didnât trust though I used continuous span engineered timber rafters and purlins.
he power of laminated sandwich panels.
I created a dynamic component for sandwich panel years ago but I never actually used them on a project, in saying this I am contemplating removing a trussed roof from a house in QLD Australia as its blocking all of the natural light, it looks bad and I want to add roof windows to lower the energy consumption in winter at the same time as providing natural sunlight.
I am thinking about using sandwich panels for part of the project.
Hey Sam, In Australia the overwhelming majority of rooves are using steel straps for bracing. In my time I have only seen 1 or 2 roofs or walls fully sheeted as they do in the States. In saying that the one or two rooves that were sheeted before external lining were passive homes which is becoming a thing here. I assume sheeting walls and roof is more predominant Stateside is because of earthquakes and shingles not requiring battens?
In Australia, we generally use sheet metal roofs or tile roofs with battens. The Sheet roofs will brace contribute to bracing, however, the battens would do minimal for bracing Iâd expect.
Like your brief tour of early timber framed houses Jack, butâŚ
Here in the UK, I believe oak (the primary timber for building houses with) was being eaten up at a furious rate for boatbuilding. Also, it must have been relatively expensive as the better houses often had much more timber than was strictly necessary - a question of proving that âI am so much richer than yowâ as one comedian put it. Easy to think that it was the only timber used or that the medieval houses survive because they were so well built/designed, conveniently ignoring the possibility that those that were poorly designed/built, used inferior materials, or were built in unsuitable locations, simply havenât survived.
I have often wondered why roofs that were once thatched tend to have a pitch of about 50 degrees, even long after thatch started to be replaced with terracotta tiles. Your explanation makes a lot of sense.
You must have lost a lot of boats then ![]()
I donât want to rattle up our disagreements in the past, but we also lost some boats, ofcourse. We replaced Oak by pine and fir/spruce for the beams etc. Imported from Eastern Europe and Scandinavia.
You also had more stone available, I believe. And a more stable undergound.
But that might not be the main reason for the preservation, often, the front and windows where completely renovated along the current fashion of that time and changing usage (shop/pub/resident/bed&breakfast)
Its dimensions and how it was built made it easy to adapt for the residents of the time. It is precisely this flexibility and the human scale of these houses that make them so attractive to live in.
maybe running off topic, here
We used to you old-growth hardwoord⌠That changed pretty quickly.
So I am going to renovate the home, the plan is to remove the roof and see what I can come up with to enable the winter sun to shine into the living space.
Today I modelled up the home as it stands currently from a plan I received from the estate agent.
I will create a new post guys as I think the process will help newcomers.
BTW this is my home in Queensland Australia so itâll be a drawn-out process in between work. Here is a screenshot of the model.
Hey guys this is what I am thinking of doing for the natural light.
I am working on the room layout as well I will send some screenshots for feedback after.
A number of years ago I gave a short course on roof framing. One of the carpenters was from the great southern continent and used the same nomenclature to describe a âframedâ roof versus a truss roof. Every roof has a pitch, even âflatâ roofs & roofs made with trusses have a pitch, eh.
At the end of the course the carpenter from Oz was able to accurately describe all the parts of a hand cut roof, so things worked out well for him. The rest of us had a harder time quitting the, âG-dayâ or âCobberâ.
This is working out nicely. The name of the thread is odd, since it has long left that topic behind.
Thatâs my bad, I have two threads going and I put the last uploaded video in the wrong spot.
Yep youâll probably find that Kiwis and Poms call them similar things to Aussies.
Technically I think your frame/cut roof makes more sense than pitched so ill give you that one. However, thereâs no way you can convince me the imperial system is good, unless you have 12 fingers anyway.
I must use inches and feet in the US. But now with my range finder i only do house measurements in decimal inches. So much easier to record and input to the computer. I default to .25 inch increments because that is what is expected and any critical dimension must be verified in remodels anyway.
Iâve been working in both systems since the late 70âs when metric became official. The worst memory I have about the change-over was having plans for a university building in metric along with imperial materials. The two do not mesh well ! I dimension my drawings in imperial, thatâs what most builders still use for residential in BC. Designing a reno in metric here is just asking for trouble.
We would normally build trusses on site with plywood gussets before the truss industry became much of a thing, and if a ceiling was called for. The locally favourite truss style is one with the exterior pitch greater than the ceiling pitch, creating a âcathedralâ ceiling. Thatâs what the realtors call it, I call it a Pitched Ceiling Truss ![]()
We call it a scissor truss (or maybe that should be âscissorsâ truss) but cathedral ceiling and vaulted ceiling are general terms that are also used. âPitchedâ just means sloped which is true of all roofs, but not all ceilings, and doesnât indicate type of framing (stick or rafters vs. truss) around here AFAIK.
Hey guys sorry for the slow reply, I have been busy.
I hear you @pbacot
I did my carpentry apprenticeship with a Dutch Kiwi, it was hard enough to understand his accent never mind he was an imperial guy and I was a metric guy.
He used to yell from the roof âCut me twentsux lengths of three by four @ Suxtyfour and a quarter & hurry up!â I had a metric and imperial tape measure that I purchase myself because he was the biggest tightwad that ever placed foot in Sydney.
Yes, I have a fair few Canadian builders and architects that I do PlusSpec training with. Using imperial material with metric dimensioning is simply unfathomable for me. I really think countries need to stick with one or the other as both together is confusing.
Australia changed from metric to imperial in July 74, I was born in 75 so I dealt with both just a little bit, fortunately now inches and feet are rarely used and we just get on with it.
I have one more comment on the pitched roof phrase that adds a slight bit of logic, (Very very slight). When put up a tent do you pitch it?
This is what we call framed roof members in Australia, I think they are similar there?
