The Feature Requests category
Firstly, I want to say how much I enjoy using Sketchup, coming back to using a CAD package after being away for over 23 years. Its intuitive and easy to use interface is great.
Now to my feature request.
I would love to be able to use Sketchup with Blender with a more seamless workflow by having an option to import/export native Blender format files directly.
This would allow users of Sketchup to take advantage of Blenders animation and rendering capabilities even more so now that chaos group (creators of VRay) have released a beta version of their rendering software to work with Blender.
This would open up a whole new area for Sketchup users.
Please note: - Blender 3.xx has Sketchup plugin that only works on Windows Pc, unfortunately its not compatible with the latest versions of Sketchup.
I would like to propose that a rating and review section be added to tthe Extension Warehouse… like every other app store. I believe this would not only provide valuable information for SU users considering adding an extension but may be a good source of metrics for informing extension developers how well their app is performing.
Additionally, I would request that Trimble require extensions in the Extension Warehouse to only be downloaded and installed via the Extension Warehouse as opposed to being redirected to an developer’s website via the ā€œVisit Extension Siteā€ button.
I request this after having recently used the Visit Extension Site button which redirected me to the extension developer’s website in my browser to download the .rbz file. Not only did the developer’s site seem far less trustworthy than the Extension Warehouse (even my computer was concerned enough to ask me, ā€œAre you sure you want to download this file?ā€), but it is simply easier to install extensions through the Warehouse. Maybe it’s just me but I prefer that ā€œwalled gardenā€ approach to app/plugin curation.
I use CAD to build things. Being able to work efficiently is essential to me, so that I can deliver results for my customers at the lowest possible price. While SketchUp is a dream come true (I started with AutoCAD in 89), there are deficiencies that make things take longer than they should. So here is my current list of improvements I’m looking for:
Right Click an object to access and edit all properties!!!
This one is huge, and can really speed up modeling. When any object or entity is right clicked, all of the attributes should be displayed, and should be able to be edited. For instance, if a line is right-clicked, the color of the line should be displayed, and be able to be changed. Compare that with changing the color of a line currently, or editing the properties of a dimension.
All of the attributes of an entity, or object, that can be edited, should be easy to edit.
Ortho mode for Line Drawing
Constraining lines to be drawn in X, Y, or Z should be the default. A user should not have to remember to hit a key to constrain line drawing.
Move important Layout features into Pro, and get rid of Layout.
Switching back and forth between two separate programs within the same application makes no sense whatsoever. Since I have been using SketchUp, I’ve heard endless complaints about Layout. There’s simply no sensible reason for it.
For dimensions, add "baseline dimensioning, and add angle dimensioning.
Baseline dimensioning is essential for contractors when doing framing layout. Stepping measurements is a forbidden practice for professional builders.
Not being able to dimension angles is ridiculous.
Rounded, Chamfered, and Beveled edges for objects
Users should be able to specify all parameters, and should be able to create fillets.
Make zooming in and out consistent, in contrast to having cursor on an object when zooming in or out.
This is, without question, one of the most irritating, and time wasting defects in Sketchup. If your cursor is not on a specific object, the zooming in or out is random, and causes unnecessary delay when modeling.
Cutting openings in layered solids, such as walls with siding and paneling.
This should be standared.
Slicing solids.
There should be a slicing tool to slice up solids, and the sliced solids should remain as separate solids, not raw geometry.
Polyline.
It is standard in vector drafting software to have a polyline option. The user should be able to add nodes, and be able to convert the polyline to a curve.
Bezier Curve.
A Bezier curve tool is standard in vector drafting software
OSNAP needs substantial improvement. Look at AutoCAD OSNAP options.
A user should be able to specify exactly what nodes should be snapped to, and when any of the specified nodes is selected, it should be prominently indicated, without being hidden by the cursor, and that includes finding the
I’ve been using pro since the mid 2000’s, here are some features I’d like to see:
Native fillet function (3D)
Ability to do small radius circles and radii: currently, I have to scale me models 10x, build them, then shrink them to 1/10.
Bring back the ā€˜save as’ to down save to older versions.
More varied woodgrain pochette in patterns (black and white)
Bring back the print preview with all the features.
Dude, the scale should have a function to alternate the axes like alt
like move you click alt and it alternates the points
corners, middles, ends, center
yes.it concerns modeling from point clouds..i hope not to hurt ā€œscan essentialsā€ users but this plugin cannot be compared to ā€œtrimble scan explorerā€ whith must have been developped by a genius…TSE is exactly what we need when you want to create a 3D model and not be puzzled by a huge amount of points one above the other and especillay when you have not been on the site and somebody has made the scans for you. I could write a book to praise the invention of this plugin. There must be many good reason for those who commercialized TRIMBLE products but when you have such a great plugin not commercialize it also as an alterative to SCAN essentials. I could demonstrate its use to TRIMBLE developpers if they want. I can boast of been on of the oldest user of SKETCHUP and I know what I am telling..best regards
How about a SHOPPING CART feature where you could save your favorite models that are actual real world confirmed products. This would encourage more companies to use the Warehouse as a store front. It could include purchasing links and a checkout page that sends an email to the company with your cart details and your contact information. Is there anything like this already being discussed?
Hello! It would be great to have more 3D tools such as: chamfer, round corners, extrude multiple faces at once, mirror tool that copies or flips elements. There are many more examples, but these are the ones that come to my mind. I’ve been using Sketchup since I was a student and in my opinion it’s a great, simple and intuitive tool and I’d love to keep using it!
Cheers
There is a mirror tool in SketchUp for a while now..
Maybe its time to update, new features/ tools are not going into SketchUp 2022..
Can we please have a dead simple threads tool for SketchUp Web / SketchUp Go subscribers? It’s possible to create threads but it is a very tedious process and for those of us using SketchUp for incidental simple 3D printbig, the cost of higher subscriptions to get Desktop don’t make financial sense when we can use Fusion360 for free. Fusion360 however is a lot more complicated and many of us do not need all of that and have much simpler needs. The one place where I’ve found SketchUp falling short is creating standard SAE and Metric threads. It’s possible in Web, it’s just a very simple 97 step process that you have to follow to the letter.
Please give us a simple threads tool to apply standard SAE and Metric threads to a selected cylinder.
When drawing arcs and circles a small on-screen indication of how many segments it is? I can’t count the number of times I changed the number sides to something big for a particular feature and an hour later see that everything I’ve done now has too many sides making the model too big.
Hello SketchUp Team,
I am a SketchUp user and would like to request the return of an official SketchUp app for Android
Many users around the world use Android devices, and having an official app would greatly improve workflow and accessibility.
Please consider bringing back support for Android.
Thank you!
If you mean the SketchUp viewer for Android, +1 from me!
I don’t mean SketchUp viewer, but actually for work, like the iPad app.
I also hope to work on an app for Android tablets.
Now I am confused, there has never been SketchUp for Android..
So how can they bring it back??
I mean that it should work on an application compatible with the Android system, not a reinstall.
في Ų§Ł„Ų«Ł„Ų§Ų«Ų§Ų”ŲŒ ٢٧ ŁŠŁ†Ų§ŁŠŲ± ٢٠٢٦، ٔ٠:٢٩ Ųµ Herman <notifications@sketchup.discoursemail.com> كتب:
Feature Request: Stable Performance with Network/Server-Based Files
I work at an architecture firm running a standard on-premises Windows Server setup. Our entire project library lives there — SketchUp models, LayOut files, shared assets like logos and line types, reference files, everything. This is not unusual. This is how the AEC industry works.
In fact, the demand for reliable network file access in architecture and engineering is so widespread that an entire category of third-party infrastructure products exists specifically to solve it — solutions built around Windows file servers and NAS systems with project folders organized by client, project, and discipline. AutoCAD, Revit, Civil 3D — these tools are explicitly called out as supported in that ecosystem. SketchUp is too, which makes it all the more frustrating that working with SketchUp files from a network drive produces the problems it does.
And those problems are specific and repeatable:
  • Crashes on save/open — SketchUp crashes or hangs when saving to or opening from the server, particularly on larger models. This has been happening for years, not occasionally.
  • LayOut reference links breaking — LayOut loses track of referenced SketchUp files the moment they’re on the server. Move a folder, rename a directory, or have a colleague open the file from their machine, and the references are gone. Relinking them is manual every time.
  • Persistent lag — Even on a fast local network, working with server-based files produces noticeable sluggishness. Viewport updates, rendering, navigating a model — all slower than they should be.
The workaround support provided is to copy everything to a local drive before working. That’s not a solution. It creates duplicate files, immediately breaks shared references, introduces version control problems, and defeats the entire point of having a server. No one at a multi-person firm can actually operate that way.
I understand Trimble Connect exists. That’s not an answer for firms that manage their own on-premises infrastructure for security, compliance, or data sovereignty reasons — or who simply need multiple people accessing the same files simultaneously without routing everything through a third-party cloud platform.
Other professional design software handles network file access without this level of instability. Expecting architects to work differently from every other tool in their stack is not a reasonable position.
The ask: Make SketchUp and LayOut genuinely stable when project files live on a Windows Server or similar on-premises network environment. Specifically: reliable save/open behavior, persistent LayOut reference paths across machines, and performance that doesn’t degrade just because the file isn’t local.
Where did you get this information? Trimble Connect is included in your SketchUp subscription. With unlimited storage..
Hello, I am a high school student in Korea who uses an iPad for home modeling with SketchUp.
I would really like to request the ability to make object edges thinner. It would be even better if the line thickness could be adjusted.
When I turn off the edges, it becomes difficult to work, but when I turn them on, the lines are too thick. For thin objects, even after applying materials, the edges dominate the view, making it hard to see the actual surface.
Because of this, I feel that the overall quality of my work is reduced.
I wasn’t sure where to send this feedback, so I’m leaving it here. I would greatly appreciate it if this feature could be considered. Thank you
