I have just renewed my student version of sketchup - what I had before was Pro and now I have Studio as I’m told this is what they give students now. Everything seems to be the same so far apart from I cannot work out how to scale textures. Everywhere I have looked says select face > right click > texture> position. I don’t have the option of ‘texture’ in the drop down when I click. Also when i go to edit > face >there is no ‘texture’ option in here as usual. Please can someone help?
Looks like you have painted the material on some faces directly and others are an overall group paint.
If you attach the group someone will check it for you.
Is this a texture you have brought in, I suspect you just aren’t understanding how images are projected when used as materials.
The pattern on the side is most likely the projection of the pattern on the top stretching along the vertical. But without your model to look at we can only guess.
