Hi, I need some advice.
I have the new SketchUp Pro 2022 and I can’t work with the TEXTURE/POSITION feature. This feature is not working and I can’t see it.
Thank you for your response.
As always, the option is only available if you select a single face with a texture. It doesn’t work with groups, components or surfaces.
You probably painted the group or component instead of the faces…
This tool is only available in the context-menu when you select a single face with a textured material.
If you have applied a textured material onto a group or component-instance it is NOT available.
PS: @Ansii beat me to it !
