Hi…I have this problem with my SketchUp…when I open the paint/texture palette, more than half of the texture options are empty. I get only colored squares…
Also, the “color in model” option doesn’t work anymore…I clic the House icon and nothing happens…
Anyone has a solution for me?
Thanks
I think this is a bug with the French edition.
See the post below by @colin
DaveR
January 7, 2025, 10:27pm
3
This is with SketchUp 2021 and Mac OS Monterey?
I am on Skp2024…and Montery 12.7.6
So I should switch to English? Or is there a way to unbug this?
colin
January 7, 2025, 10:31pm
6
Check this post I made at the time:
There was another topic about this, where I gave more instructions:
The fix that came out in the 2023.0.1 update should prevent the double entry and empty in model issue from happening. But, you may need to do this extra steps after the update:
In Finder, Go menu, Go to Folder… paste in this path:
~/Library/Colors/
In that folder, delete any .clr files. You’re likely to recognize some of the names!
Reopen SketchUp and see if your language is the only in model entry, and that it has material…
DaveR
7
Fix your forum prodfile, please.
Hi…not sure to understand…this path doesn’t bring me anywhere…
I tried to change language and now I have English and French in my material library. English show the textures and work…French doesn’t. Does that mean I have to stay with English to work?
colin
January 7, 2025, 11:15pm
9
The fix I gave worked for other languages.
In case the instructions weren’t clear, you would go to Finder, and from the Go menu you would choose Go to Folder… and paste in this path:
~/Library/Colors/
In there you should see some files. Delete any of the files that end with .clr
colin:
~/Library/Colors/
Yesssssssssssssssssss!!! Got it this time!!!
Thank you so much!!! It worked. I flip back to French and it all works now.
Very helpful…
Thanks!!! Happy 2025 full of cool projects!
Should be fixed now…sorry
system
Closed
July 12, 2025, 10:15pm
12
This topic was automatically closed after 186 days. New replies are no longer allowed.
