I’ve encountered the problem with both .png and .jpg, so the format doesn’t appear to matter. Unfortunately I cannot share the .skp file or the textures as I’m presently working with stuff that’s under NDA. I’ve uploaded some screenshots that help illustrate the problem, though.
This is a screenshot taken of a segment of one of the textures I’m using as it appears within Photoshop, Affinity, and Preview.
But then I apply the textures to geometry in the model and, without touching any settings that I’m aware of, they desaturate. It should be noted that the center segment - which has its own unique texture applied - is the color the two sides SHOULD be, even when accounting for shadows and gradients. For whatever reason, that center texture applies without any problem, but applying the other two results in something muddy.
I really wish I could just upload the .skp file and let y’all monkey with it, but I hope these thumbnails at least better explain the problem I’m having.
Sorry. Those images, especially the tiny little thumbnails, don’t help to identify the problem. Can you get this to happen with an image and model that isn’t covered by your NDA? If so, maybe you could share the SKP file for that.
That’s the problem. Open the .jpg I posted by itself in Preview, Paint, whatever will open a standalone .jpg. It should be bright orange like in the first screenshot I posted. But when I posted the file itself, the forum here is also showing it with a reduced brightness and contrast, and when imported into SketchUp, the B&C go way down.
The original file should be showing bright, vibrant colors. When imported into SketchUp it gets dark and muddy.
I’m not seeing the bright orange color in the image you uploaded before Aaron’s screenshot. the Banner segment jpg file you upload is not bright like in your earlier posts.
When you download “Banner Segment.jpg” and open it on your computer in something other than SketchUp - something like Preview or Paint or even Photoshop - it it still showing up as muddy and brown, or does it show up bright orange like in “Original Color.png”?
Well, You’re seeing it as brown in SketchUp. Aaron and I see the same thing. Only Preview seems to be showing it as orange. I would be suspicious of Preview instead of SketchUp.
I get the same bright orange in Safari, Photoshop CC, Affinity Photo, and in Outlook and Mail when sent as an email attachment. Though, interestingly, I get something between the orange and the brown - though closer to the brown - when I open it in Firefox.
That image has a color sync profile attached to it. When you remove the color sync profile you have attached by doing (on Mac, from Terminal)
sips -d profile --deleteColorManagementProperties
You get exactly the dulled image. You’ve somehow applied a color sync profile to correct it, which Preview picks up.
To see the color sync profile, in SketchUp right click on texture and click “Edit Texture Image”. That image opens in Preview.app, so hit cmd-I and look at it: General Info says you have a Color Sync profile of “HDR DCI P3/D65 Display - White Point D65, EOTF SMPTE ST 2084” applied to it.
Dan, the “Original Color.png” was just a screenshot, not the working file. I took the working file, exported as a .png instead of .jpg and ran into the exact same problem when I imported it into SketchUp.
I think Barry might be on the right track as both my working files and the sample files I’ve attached here that have given me problems have been run through either Photoshop CC or Affinity Photo, both of which will attach Color Sync or Color Management profiles. I’ll have to fuss with those to see if I get anything from them.
Hi, I don’t know if this is still relevant now, but it might be helpful to future Google searches regarding this topic.
This happened to me also and I was able to solve it by setting the GL capabilities to its max.
