I am using Sketchup pro 2021
coloana muista.skp (1.7 MB)
i attached the column
Please correct your forum profile. Presumably you have a subscription. You might consider upgrading to 2023.
Natively you can expose the hidden geometry, sample the texture on one face, and paint it on the next faces.
Your texture isnāt tall enough for the column so you will have repetition vertically. You can edit the material and make it larger or stretch it in the vertical direction or look for a more suitable material.
I made a quick sample in SU2023 and the texture went on without any problem.
thanks for response Dave
dosenāt work for me this solution,i tried but when i color the face nothing happened
The ideea is if i try only the column is ok but i replaced
the cplumns in a big building and then appear the problem
Thatās odd. Is the model placed at a large distance from the origin?
Did you try correcting it in the large model?
Fix your forum profile.
We have it fixed internally, I canāt say when an update will include the fix.
Colin, what was the root of the issue? What changed?
Its a chronic problem for my workflow.
Glad it was addressed and found.
Iām having the exact same issue. I was using SketchUp Pro version 22.0.354 and I could map textures to curved surfaces accurately and easily by turning on hidden geometry and sampling face etc. however since Iāve updated to the latest 2023 version I cannot get the same results, the textures get all messed up just like the samples shown above. Iām also having trouble with āThrupaintā
This is still a problem I am havingā¦ I can only get something to work with a projected texture
You are going to have to use an older version of SKP until they update the current version to fix it.
To all suffering - just install free sketchUV or ThruPaint ($, somehow better) and watch the relevant TutorialsUp vids
